查看: 231|回复: 12
求助---stm32F407不能进入接收中断
29
29
2019-7-18
18 小时
发表于 2019-7-18 12:56:14 | 显示全部楼层 |阅读模式
小弟最近在做RS232与PC机的通信实验,使用探索者F407串口2自带的RS232接口,发现一直进不到接收中断函数里面。求大佬指点迷津。附中断程序代码和相关程序文件。
//接收缓存区
u8 RS232_RX_BUF[64];          //接收缓冲,最大64个字节.
//接收到的数据长度
u8 RS232_RX_CNT=0;
void USART2_IRQHandler(void)
        u8 res;
        u8 rs232_tmp_buf[5];
        rs232_tmp_buf[0]=1;
        rs232_tmp_buf[1]=2;
        rs232_tmp_buf[2]=3;
        rs232_tmp_buf[3]=4;
        rs232_tmp_buf[4]=5;
        RS232_Send_Data(rs232_tmp_buf,5);
        LED0=!LED0;
        if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)//接收到数据
                //USART_ClearITPendingBit(USART2,USART_IT_RXNE);
//          res =USART_ReceiveData(USART2);//;读取接收到的数据USART2->DR
                res =USART_ReceiveData(USART2);//(USART1->DR);        //读取接收到的数据
                USART_SendData(USART2,res);
                while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束
//                if(RS232_RX_CNT<64)
//                        RS232_RX_BUF[RS232_RX_CNT]=res;                //记录接收到的值
//                        RS232_RX_CNT++;                                                //接收数据增加1
//                        rs232_tmp_buf[0]=RS232_RX_CNT;
//                        rs232_tmp_buf[1]=RS232_RX_CNT;
//                        rs232_tmp_buf[2]=RS232_RX_CNT;
//                        rs232_tmp_buf[3]=RS232_RX_CNT;
//                        rs232_tmp_buf[4]=RS232_RX_CNT;
//                        RS232_Send_Data(rs232_tmp_buf,5);
//                        while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束
//初始化IO 串口2
//bound:波特率
void RS232_Init(u32 bound)
        USART_InitTypeDef USART_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE); //使能GPIOA时钟
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);//使能USART2时钟
  //串口2引脚复用映射
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource2,GPIO_AF_USART2); //GPIOA2复用为USART2
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource3,GPIO_AF_USART2); //GPIOA3复用为USART2
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_100MHz;
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_2;//
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF;//
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
        GPIO_Init(GPIOA,&GPIO_InitStructure);//TX
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
   //USART2 初始化设置
        USART_InitStructure.USART_BaudRate = bound;//波特率设置
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
        USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
        USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;        //收发模式
  USART_Init(USART2, &USART_InitStructure); //初始化串口2
  USART_Cmd(USART2, ENABLE);  //使能串口 2
        USART_ClearFlag(USART2, USART_FLAG_TC);
        USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//开启接受中断
        //Usart2 NVIC 配置
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;//抢占优先级3
        NVIC_InitStructure.NVIC_IRQChannelSubPriority =3;                //子优先级3
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
        NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器、
//RS232发送len个字节.
//buf:发送区首地址
//len:发送的字节数(为了和本代码的接收匹配,这里建议不要超过64个字节)
void RS232_Send_Data(u8 *buf,u8 len)
        u8 t;
          for(t=0;t<len;t++)                //循环发送数据
          while(USART_GetFlagStatus(USART2,USART_FLAG_TC)==RESET); //等待发送结束
    USART_SendData(USART2,buf[t]); //发送数据
        RS232_RX_CNT=0;
//RS232查询接收到的数据
//buf:接收缓存首地址
//len:读到的数据长度
void RS232_Receive_Data(u8 *buf,u8 *len)
        u8 rxlen=RS232_RX_CNT;
        u8 i=0;
        *len=0;                                //默认为0
        delay_ms(10);                //等待10ms,连续超过10ms没有接收到一个数据,则认为接收结束
        if((rxlen==RS232_RX_CNT)&&rxlen)//接收到了数据,且接收完成了
                for(i=0;i<rxlen;i++)
                        buf=RS232_RX_BUF;
                *len=RS232_RX_CNT;        //记录本次数据长度
                RS232_RX_CNT=0;                //清零
实验4 串口实验.zip
4.01 MB, 下载次数: 2
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_Pin=GPIO_Pin_2;// GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF;// GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉 GPIO_Init(GPIOA,&GPIO_InitStructure);//TX GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; G ...
29
85
85
2019-7-17
18 小时
发表于 2019-7-18 12:56:15 | 显示全部楼层
        GPIO_Init(GPIOB,&GPIO_InitStructure);
RX 管脚没复用配置吧,推荐使用 CUBEMX 软件,自动生成基本配置
29
29
2019-7-18
18 小时
 楼主| 发表于 2019-7-18 17:12:04 | 显示全部楼层
我看网上的例程是这样设置的。而且RX的复用配置应该是共用了第一个的变量。现在是stm32发送给上位机的数据PC端都能收到,但是PC发送给stm32就接收不到
97
463
463
2011-5-15
92 小时
发表于 2019-7-18 18:03:50 | 显示全部楼层
2楼正解
Mode 都是 AF 才对
29
29
2019-7-18
18 小时
 楼主| 发表于 2019-7-18 18:30:48 | 显示全部楼层
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //í&#198;íì&#184;′ó&#195;ê&#228;3&#246;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //é&#207;à-
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
        GPIO_Init(GPIOA,&GPIO_InitStructure);//RX
修改成复用模式,还是不行
29
29
2019-7-18
18 小时
 楼主| 发表于 2019-7-18 19:24:27 | 显示全部楼层
发现一个非常奇怪的现象,当我把RS232接口反复插拔,在这个不断插拔的时间段,程序就能进入中断传数据了,只要接口一旦接好,就又不行了。stm32和PC我用的是RS232转USB的转接线,会不会是这个接口的问题?
29
85
85
2019-7-17
18 小时
发表于 2019-7-18 19:49:56 | 显示全部楼层
如果你用的是开发板的话,相应的管脚应该是引出来了,如果你怀疑接口的问题,可以买个USB 赚 TTL 的工具,跳过232 ,直接连接UART。
GPIO_OType_OD 这个是开漏,你确认是管脚外接了上拉电阻了 ?
29
29
2019-7-18
18 小时
 楼主| 发表于 2019-7-18 20:20:13 | 显示全部楼层
这是我最后试验的代码,就出现了上述接口的问题。(不过上拉、开漏我是真的不懂
29
29
2019-7-18
18 小时
 楼主| 发表于 2019-7-18 20:24:09 | 显示全部楼层
file:///E:/SoftWares/QQ/qq%20download/634860378/FileRecv/MobileFile/IMG_20190718_202217.jpg
这是开发板和转接头
29
85
85
2019-7-17
18 小时
发表于 2019-7-19 09:15:14 | 显示全部楼层
我仿佛看到你的那个工具是 USB-485 ? 你确定是 USB-232 ?
29
85
85
2019-7-17
18 小时
发表于 2019-7-19 09:25:19 | 显示全部楼层
看你的代码使用串口的管脚是PA2,PA3,
你确定你使用的那个232接口是连接到了MCU的这两个管脚上了?
找找官方的原理图看下怎么连接的?
几年之前我也是买的这种板子,还有个跳线帽,别搞错了
29
29
2019-7-18
18 小时
 楼主| 发表于 2019-7-19 09:53:06 | 显示全部楼层
他这个转接头原先是rs485转232再转USB的,我把485转232部分的拆了,剩下232转USB的模块
29
29
2019-7-18
18 小时
 楼主| 发表于 2019-7-19 09:53:56 | 显示全部楼层
找找 ...
跳线帽确定接对的
正点原子酷炫Linux来了,猛击上一条 /1 下一条
QQ|手机版|官方淘宝店|微信公众平台|OpenEdv-开源电子网 ( 粤ICP备12000418号-1 )
GMT+8, 2019-8-20 13:05
