查看: 365|回复: 1
关于多任务调度时,RETI执行后PC本该是01A1,可怎么变为0101啊
29
29
2016-12-23
发表于 2017-1-7 12:56:00 | 显示全部楼层 |阅读模式
void OSStartTask() 函数中RETI执行后PC本该是0x01A1,可怎么变为0x0101啊
下面是“建立一个属于自己的 AVR 的 RTOS.pdf”中的程序
#include <avr/io.h>
#include <avr/Interrupt.h>
#include <avr/signal.h>
unsigned char Stack[400];
register unsigned char OSRdyTbl          asm("r2");    //任务运行就绪表
register unsigned char OSTaskRunningPrio asm("r3");    //正在运行的任务
#define OS_TASKS 3                    //设定运行任务的数量
struct TaskCtrBlock
  unsigned int OSTaskStackTop;  //保存任务的堆栈顶
  unsigned int OSWaitTick;      //任务延时时钟
} TCB[OS_TASKS+1];
//防止被编译器占用
register unsigned char tempR4  asm("r4");
register unsigned char tempR5  asm("r5");
register unsigned char tempR6  asm("r6");
register unsigned char tempR7  asm("r7");
register unsigned char tempR8  asm("r8");
register unsigned char tempR9  asm("r9");
register unsigned char tempR10 asm("r10");
register unsigned char tempR11 asm("r11");
register unsigned char tempR12 asm("r12");
register unsigned char tempR13 asm("r13");
register unsigned char tempR14 asm("r14");
register unsigned char tempR15 asm("r15");
register unsigned char tempR16 asm("r16");
register unsigned char tempR16 asm("r17");
//建立任务
void OSTaskCreate(void (*Task)(void),unsigned char *Stack,unsigned char TaskID)
  unsigned char i;
  *Stack--=(unsigned int)Task>>8;    //将任务的地址高位压入堆栈,
  *Stack--=(unsigned int)Task;         //将任务的地址低位压入堆栈,
  *Stack--=0x00;                     //R1 __zero_reg__
  *Stack--=0x00;                     //R0 __tmp_reg__
  *Stack--=0x80;
//SREG 在任务中,开启全局中断
  for(i=0;i<14;i++)    //在 avr-libc 中的 FAQ 中的 What registers are used by the C compiler?
    *Stack--=i;                    //描述了寄存器的作用
  TCB[TaskID].OSTaskStackTop=(unsigned int)Stack;    //将人工堆栈的栈顶,保存到堆栈的数组中
  OSRdyTbl|=0x01<<TaskID;      //任务就绪表已经准备好
//开始任务调度,从最低优先级的任务的开始
void OSStartTask()
  OSTaskRunningPrio=OS_TASKS;
  SP=TCB[OS_TASKS].OSTaskStackTop+17;
  __asm__ __volatile__(    "reti"       " \t"  );
//进行任务调度
void OSSched(void)
   //  根据中断时保存寄存器的次序入栈,模拟一次中断后,入栈的情况
  __asm__ __volatile__("PUSH __zero_reg__ \t");  //R1
  __asm__ __volatile__("PUSH __tmp_reg__\t");  //R0
  __asm__ __volatile__("IN   __tmp_reg__,__SREG__\t");  //保存状态寄存器 SREG
  __asm__ __volatile__("CLR  __zero_reg__ \t");  //R0重新清零
  __asm__ __volatile__("PUSH R18\t");
  __asm__ __volatile__("PUSH R19\t");
  __asm__ __volatile__("PUSH R20\t");
  __asm__ __volatile__("PUSH R21\t");
  __asm__ __volatile__("PUSH R22\t");
  __asm__ __volatile__("PUSH R23\t");
  __asm__ __volatile__("PUSH R24\t");
  __asm__ __volatile__("PUSH R25\t");
  __asm__ __volatile__("PUSH R26\t");
  __asm__ __volatile__("PUSH R27\t");
  __asm__ __volatile__("PUSH R30\t");
  __asm__ __volatile__("PUSH R31\t");
  __asm__ __volatile__("Int_OSSched: \t");  //当中断要求调度,直接进入这里
  __asm__ __volatile__("PUSH R28\t");  //R28与R29用于建立在堆栈上的指针
  __asm__ __volatile__("PUSH R29\t");  //入栈完成
  TCB[OSTaskRunningPrio].OSTaskStackTop=SP;           //将正在运行的任务的堆栈底保存
  if(++OSTaskRunningPrio>=OS_TASKS) //轮流运行各个任务,没有优先级
      OSTaskRunningPrio=0;
  //cli();  //保护堆栈转换
  SP=TCB[OSTaskRunningPrio].OSTaskStackTop;
  //sei();
    //根据中断时的出栈次序
  __asm__ __volatile__("POP  R29\t");
  __asm__ __volatile__("POP  R28\t");
  __asm__ __volatile__("POP  R31\t");
  __asm__ __volatile__("POP  R30\t");
  __asm__ __volatile__("POP  R27\t");
  __asm__ __volatile__("POP  R26\t");
  __asm__ __volatile__("POP  R25\t");
  __asm__ __volatile__("POP  R24\t");
  __asm__ __volatile__("POP  R23\t");
  __asm__ __volatile__("POP  R22\t");
  __asm__ __volatile__("POP  R21\t");
  __asm__ __volatile__("POP  R20\t");
  __asm__ __volatile__("POP  R19\t");
  __asm__ __volatile__("POP  R18\t");
  __asm__ __volatile__("POP  __tmp_reg__\t");      //SERG 出栈并恢复
  __asm__ __volatile__("OUT  __SREG__,__tmp_reg__ \t");      //
  __asm__ __volatile__("POP  __tmp_reg__ \t");      //R0 出栈
  __asm__ __volatile__("POP  __zero_reg__ \t");      //R1 出栈
  __asm__ __volatile__("RETI\t");     //返回并开中断
  //中断时出栈完成
void IntSwitch(void)
  __asm__ __volatile__("POP  R31\t");  //去除因调用子程序而入栈的 PC
  __asm__ __volatile__("RJMP Int_OSSched\t");  //重新调度
void TCN0Init(void)    // 计时器 0
  TCCR0 = 0;
  TCCR0 |= (1<<CS02);  // 256预分频
  TIMSK |= (1<<TOIE0); // T0溢出中断允许
  TCNT0 = 100;         // 置计数起始值
SIGNAL(SIG_OVERFLOW0)
  TCNT0=100;
  IntSwitch();        //任务调度
void Task0()
  unsigned int j=0;
    PORTB=j++;
    //OSTimeDly(50);
void Task1()
  unsigned int j=0;
    PORTC=j++;
    //OSTimeDly(5);
void Task2()
  unsigned int j=0;
    PORTD=j++;
    //OSTimeDly(5);
void TaskScheduler()
     OSSched();      //反复进行调度
int main(void)
  TCN0Init();
  OSRdyTbl=0;
  OSTaskCreate(Task0,&Stack[99],0);
  OSTaskCreate(Task1,&Stack[199],1);
  OSTaskCreate(Task2,&Stack[299],2);
  OSTaskCreate(TaskScheduler,&Stack[399],OS_TASKS);
  OSStartTask();
29
29
2016-12-23
 楼主| 发表于 2017-1-9 11:50:56 | 显示全部楼层
为什么我在用中断RETI返回,PC指针指向的地址不是想到的地址
GMT+8, 2018-2-19 02:26
