查看: 5262|回复: 6
STM32H7已上线,厉害了Nucleo- H743ZI,主频400MHz!
209
209
2016-8-25
53 小时
发表于 2017-11-12 23:32:45 | 显示全部楼层 |阅读模式
The STM32 Nucleo-144 boards provide an affordable and flexible way for users to try out new concepts and build prototypes by choosing from the various combinations of performance and power consumption features, provided by the STM32 microcontroller.
The ST Zio connector, which extends the Arduino™ Uno V3 connectivity, and the ST morpho headers provide an easy means of expanding the functionality of the Nucleo open development platform with a wide choice of specialized shields.
The STM32 Nucleo-144 board does not require any separate probe as it integrates the ST-LINK/V2-1 debugger/programmer.
The STM32 Nucleo-144 board comes with the STM32 comprehensive free software libraries and examples available with the STM32Cube package.
Key Features
  • STM32 microcontroller in LQFP144 package
  • SMPS: significantly reduces power consumption in Run mode, by generating Vcore logic supply from an external DC/DC converter. This function is only available on ‘-P’ suffixed boards
  • LSE crystal: 32.768 kHz crystal oscillator
  • USB OTG or full-speed device(depending on STM32 support)
  • Ethernet compliant with IEEE-802.3-2002 (depending on STM32 support)
  • 3 user LEDs
  • 2 user and reset push-buttons
  • Board connectors:
    • USB with Micro-AB
    • SWD
    • Ethernet RJ45 (depending on STM32 support)
  • Board expansion connectors:
    • ST Zio connector including Arduino™ Uno V3
    • ST morpho
  • Flexible power-supply options:
    • ST-LINK USB VBUS or external sources
  • On-board ST-LINK/V2-1 debugger/programmer with USB re-enumeration capability: mass storage, virtual COM port and debug port
  • Comprehensive free software libraries and examples available with the STM32Cube package
  • Support of a wide choice of Integrated Development Environments (IDEs) including IAR™ , Keil® , GCC-based IDEs
附件是手册
随便告诉大家个好消息,
https://item.taobao.com/item.htm?spm=a1z10.3-c-s.w4002-17018104769.10.3cdef7adpgK96r&id=560793930687
这家店铺有售,,为答谢大家。。给本论坛网友给出团购价248,,,而且包邮。是的。没错,只要248你就能尝鲜H7芯片了。。
直接联系客服,暗号“开源电子
en.DM00357737 (1).pdf
377.52 KB, 下载次数: 354
开发板手册
正点原子逻辑分析仪DL16劲爆上市
530
165357
165357
2109 小时
发表于 2017-11-13 00:54:28 | 显示全部楼层
这是cat什么版本的?
cat1.0的,有硬件bug...
67
82
82
2016-10-23
78 小时
发表于 2017-11-13 10:48:16 | 显示全部楼层
正点原子 发表于 2017-11-13 00:54
这是cat什么版本的?
cat1.0的,有硬件bug...
原子哥请教下,芯片的cat版本要在哪里看呢
209
209
2016-8-25
53 小时
 楼主| 发表于 2017-11-13 11:04:45 | 显示全部楼层
这是cat什么版本的?
cat1.0的,有硬件bug...
正点原子大哥,你们准备什么时候推出H7的开发板。
你们准备用什么芯片呢?743、753的芯片准备量产了。753的价格好像要便宜些。你们会不会沿用176封装的F7的风格?
CAT的版本是指的芯片吗?还是开发板的版本?
请赐教!
209
209
2016-8-25
53 小时
 楼主| 发表于 2017-11-13 11:07:42 | 显示全部楼层
这是cat什么版本的?
cat1.0的,有硬件bug...
这个是什么版本,能看出来吗?
88
7377
14980
14980
2013-11-13
1823 小时
发表于 2017-11-13 15:28:11 | 显示全部楼层
wazhzhang 发表于 2017-11-13 11:07
这个是什么版本,能看出来吗?
芯片版本只有ST自己能看到,nucleo板子应该用的最早一批H7芯片,那一批H7芯片有很多bug,压根没法量产,这就是H7为什么跳票的原因,现在要量产的应该是bug修复后的版本。
开往春天的手扶拖拉机
209
209
2016-8-25
53 小时
 楼主| 发表于 2017-11-13 21:49:29 | 显示全部楼层
这个开发板是最近刚到的最新批次的。应该没有问题的
原子哥极力推荐上一条 /2 下一条
GMT+8, 2024-12-10 14:04
