查看: 11664|回复: 6
内核移植出现问题-->Ramdisk image is corrupt or invalid?
2020-1-9
发表于 2020-1-9 09:54:19 | 显示全部楼层 |阅读模式
以下是uboot信息,内核加载出现问题--》Ramdisk image is corrupt or invalid?,请问该怎么解决啊??
=> pri
baudrate=115200
board_name=EVK
board_rev=14X14
boot_fdt=try
bootcmd=run findfdt;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi
bootcmd_mfg=run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
bootdelay=3
bootscript=echo Running bootscript from mmc ...; source
console=ttymxc0
ethact=FEC1
ethprime=FEC
fdt_addr=0x83000000
fdt_file=imx6ull-14x14-emmc-4.3-480x272-c.dtb
fdt_high=0xffffffff
findfdt=if test $fdt_file = undefined; then if test $board_name = EVK && test $board_rev = 9X9; then setenv fdt_file imx6ull-9x9-evk.dtb; fi; if test $board_name = EVK && test $board_rev = 14X14; then setenv fdt_file imx6ull-14x14-evk.dtb; fi; if test $fdt_file = undefined; then echo WARNING: Could not determine dtb to use; fi; fi;
image=zImage
initrd_addr=0x83800000
initrd_high=0xffffffff
ip_dyn=yes
loadaddr=0x80800000
loadbootscript=fatload mmc ${mmcdev}{mmcpart} ${loadaddr} ${script};
loadfdt=fatload mmc ${mmcdev}{mmcpart} ${fdt_addr} ${fdt_file}
loadimage=fatload mmc ${mmcdev}{mmcpart} ${loadaddr} ${image}
mfgtool_args=setenv bootargs console=${console},${baudrate} rdinit=/linuxrc g_mass_storage.stall=0 g_mass_storage.removable=1 g_mass_storage.file=/fat g_mass_storage.ro=1 g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF g_mass_storage.iSerialNumber="" clk_ignore_unused
mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot}
mmcautodetect=yes
mmcboot=echo Booting from mmc ...; run mmcargs; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
mmcdev=0
mmcpart=1
mmcroot=/dev/mmcblk0p2 rootwait rw
netargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs ip=dhcp nfsroot=${serverip}{nfsroot},v3,tcp
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${image}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
panel=ATK-LCD-4.3-480x272
script=boot.scr
splashimage=0x88000000
splashpos=m,m
Environment size: 2536/8188 bytes
=> setenv bootargs root=/dev/nfs nfsroot=192.168.0.103:/home/zhou/Desktop/nfsserver/rootfs rw console=ttySAC2,115200 init=linuxrc ip=192.168.0.200   loglevel=8
=> setenv bootcmd tftp 80800000  zImage\;tftp 83000000  lora_gateway.dtb\;bootz 80800000 – 83000000
=> setenv ipaddr 192.168.0.200
=> setenv ethaddr 00:04:9f:04:d2:35
=> setenv gatewayip 192.168.0.1
=> setenv netmask 255.255.255.0
=> setenv serverip 192.168.0.103
=> saveenv
Kernel image @ 0x80800000 [ 0x000000 - 0x552f18 ]
Wrong Ramdisk Image Format
bootz 80800000 – 83000000 这个bootz指令的话要注意,-是用英文的-,而且-的两边有个空格
888
2397
2397
2019-9-25
398 小时
发表于 2020-1-9 09:54:20 | 显示全部楼层
2019-4-25
10 小时
发表于 2020-3-5 11:12:31 | 显示全部楼层
多谢,我也遇到这问题了,直接复制的指令不行
109
109
2020-2-25
19 小时
发表于 2020-4-1 21:37:55 | 显示全部楼层
2019-10-23
发表于 2020-7-27 21:49:46 | 显示全部楼层
多谢2,我也遇到了这个问题,头疼了一天,一直想是自己哪里弄错了。
445
445
2017-11-17
94 小时
发表于 2020-11-9 20:56:25 来自手机 | 显示全部楼层
多谢!!
48
263
263
2018-7-4
44 小时
发表于 2021-4-29 20:29:19 | 显示全部楼层
偷不得懒呀!命令还是自己一点点的敲吧…………
GMT+8, 2026-4-23 17:31
