- 积分
- 7
- 金钱
- 7
- 注册时间
- 2016-4-8
- 在线时间
- 0 小时
发表于 2016-4-8 16:11:28
显示全部楼层
STM32端口做AD采集用,设置为模拟输入,为什么用万用表电流档,表笔一端接IO,另一端接3.3V,能测到84ua电流呢?而且刚好3.3V/84ua约等于40k,即下拉电阻阻值。公司的模拟工程师说这说明IO对地还是有下拉电阻,但是设置为模拟输入,下拉电阻不是自然的就被禁止了吗?
void ADC_Config(void)
ADC_InitTypeDef ADC_InitStructure;
RCC_ADCCLKConfig(RCC_PCLK2_Div2);
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA,ENABLE);
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_1 |GPIO_Pin_2 | GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AIN;
GPIO_Init(GPIOA,&GPIO_InitStructure); //默认速度为两兆
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //独立模式
ADC_InitStructure.ADC_ScanConvMode =DISABLE; //ENABLE; //连续多通道模式
ADC_InitStructure.ADC_ContinuousConvMode =ENABLE; //连续转换
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //转换不受外界决定
ADC_InitStructure.ADC_DataAlign =ADC_DataAlign_Right; //右对齐
ADC_InitStructure.ADC_NbrOfChannel =1; //3 //扫描通道数
ADC_Init(ADC1, &ADC_InitStructure);
//转换序列1,2,3
ADC_RegularChannelConfig(ADC1,ADC_Channel_1, 1,ADC_SampleTime_1Cycles5); //通道X,采样时间为1.5周期,1代表规则通道第1个这个1是啥意思我不太清楚只有是1的时候我的ADC才正常。
// ADC_RegularChannelConfig(ADC1,ADC_Channel_2,2,ADC_SampleTime_1Cycles5);
//ADC_RegularChannelConfig(ADC1,ADC_Channel_3, 3, ADC_SampleTime_1Cycles5);
//ADC_DMACmd(ADC1,ENABLE);
ADC_Cmd (ADC1,ENABLE); //使能或者失能指定的ADC
//ADC 自动校准,开机后需要执行一次,保证精度
// Enable ADC1 reset calibaration register
ADC_ResetCalibration(ADC1);
// Check the end of ADC1 reset calibration register
while(ADC_GetResetCalibrationStatus(ADC1));
// Start ADC1 calibaration
ADC_StartCalibration(ADC1);
// Check the end of ADC1 calibration
while(ADC_GetCalibrationStatus(ADC1));
// ADC自动校准结束
ADC_SoftwareStartConvCmd(ADC1,ENABLE);//使能或者失能指定的ADC的软件转换启动功能
